Pressure Plate
Just slipping under load in 4th. I think I'm concluding that I have a fluid leak somewhere as pedal seems to have sagged a little bit these past few days.
I find adding fluid is just brutal with the tanks under the fender. I think I may ditch the shut off switch that was hooked to the clutch hydraulic fluid reservoir and add an adapter/valve that might enable me to add fluid without opening the reservoir in the tradtional manner. Anybody ever try that.
I found out in the meantime that the pressure plate that is in there is 2400 LBs, which I'd think would be enough........now if I can figure out why the slow leak........
I am almost getting confident driving this thing with a little throttle........street racing starts at BIR in a week or so..........would love to try some quarter miles........
