Old 05-05-2003, 10:45 AM
Hunter71 Hunter71 is offline
Default 428 build Questions need HELP
I'm building a 428CJ and I'm in the process of purchasing the parts. I'm looking at the Powermax mechcanical solid cam from Crane (344361) or (341191). I don't know if I can run this in my car because I live In California. I'm going to run Keith Black pistons .40 and Edelbrock heads. But when I'm calculating the compression ratio its in the 9:1 range. I don't know if this correct or not. My final question is my machine shop suggested to use the 850 Holley carb, but I see that most of you guys are running 750s. Need help before I spend $$$$$$$$$$$$$$$$$$$$$. Thanks, Craig
