The last time I contacted David Kee...he didn't have gears for white stripe boxes.
Call TexRacing...they do Jericos as well as T101...Rebuilt units around 3K with what ever gears you want...for road racing you need a 1st gear around 1.75, assuming you want to use it on the track...bit hard to take off.
Currently I use a Richmond 5 speed RRace version, which you get to pick your gears. Set it up to use 1-4th for short tracks with a 3.54 rear gear....gear ratios in transmission (1-4th) make car seem to have 4.56 rear (just math)...5th, is used on long tracks and will allow around 165 mph...at redline....2.9 mile track only sees around 155 mph...would probably take Road Am to see any more than that.
When I bought the Richmond about 6 years ago they were around 2.4K...don't know about now.
M
