You will like it a lot more than steel. Motor revs quicker, the engine torques over less, engine just gets snappier. You are removing a huge amount of mass from the rotating assembly, the engine accells and decells quicker due to the lower inertia. A flywheel is heavy enough if you can keep the motor idling.
