Thread: Piston Choice
Old 05-07-2003, 03:41 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I have sucessfully done 11:1 street motors than ran on 92 octane. The efficiency of the combustion chamber comes into play a lot as the line is being pushed a bit, aluminum heads are a must. Also they run closer to 11:1 air:fuel not the 13.5:1 that so many people think is always the optimum. But small block ford, single holley, over 500 ft/lbs from 2500 rpm up and over 500 hp as well. Measured at the flywheel, no correction factors.
