Old 05-08-2003, 06:18 AM
Trans-Am Jim's Avatar
Trans-Am Jim Trans-Am Jim is offline
Send a message via ICQ to Trans-Am Jim
Unless you have the blowout valve (either aftermaket or OE if newer Holley) installed in the power valve circuit, the power valve is probably toast and would cause an over-rich idle. You said you checked the valve and it "seems OK" Unless you have a power valve tester, there is really no good way to be sure. Get new ones (both carbs) and start from there.
Jimbo
