  #146 (permalink)
Old 05-10-2003, 05:30 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I think a CSX4000 car with either an iron 427 SO or a new aluminum 427 would be desireable, and would be worth about the same. It would depend upon the buyer if there was a difference. It would be worth less if it had a 428, 390 etc.
From what I have seen, I think alot of the CSX3000 cars that came with 428's have been changed to 427's. I think a CSX3000 car is worth more with a 427 SO even if the original engine was a 428. I personally know the owner of CSX325*, and he has a 427 SO service block, when his car likely originally had a 428, and it doesnt matter to him. I think most of the 427 cobra's that came with 428's were in the CSX32** range. I would think that a large percentage of original 427 cobra's don't have their original engines, but as long as they have a 427 in it, it is worth more. If it is the original 427 as installed, then I think it would worth the most.
As far as weight, I know it has been listed elseware, but, I can tell you that just the other day I help lift a 427 SO bare block into a truck, and me and another guy carried it. I bet it weighed about 180 lbs, give or take 10. The Shelby block is listed as 125 lbs. The new genesis 427 so block I think is about 250 lbs. It has much thicker siameesed cylinder walls, thicker deck, and main webs. It is heavier than the originals. I saw the cut away at a show, although I didn't carry it. I'll look for a weight listing.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
