  #104 (permalink)
Old 05-10-2003, 11:08 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Ernie, The sidepipes you have won't bolt up to the standard header. They don't reach in as far as the stock sidepipe.
I can get 302 headers for $350, plain sidepipes with the good mufflers are $350. Front Carrera coilovers run $390. Rear Pro-Shock coilovers run $390.
You will need to have the sidepipes and headers coated. They came as plain steel. The weight of the sidepipes is supported at the front by the headers. I haven't seen a problem with this and I'm pretty sure everyone does it that way. Since the motor has to move from the engine torque the only way to eliminate it is with a solid motor mount.
Don
