Old 05-11-2003, 05:05 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
OK, but aside from opening up the restrictions between the filter and the pump, why do you want to? The 427 top oiler was a fine design and enless you are going to turn it into a cammer it really isn't worth the trouble (expense)..
Before you flame me.. What are you going to gain? Will it be more valuable? NO (actually you will ruin a perfectly fine 427's historical value).. Will it be more durable? Not really..
The side oiler was developed for the SOHC 427 and was plumbed for oiling accordingly. Beyond that what will doing what you propose gain?
If you must embark on a project like this I would (ok.. I wouldn't) use a 427 industrial or marine engine.. These are the ones that "look" like side oilers with the raised oil passage on the side of the block.. They were cast but never built as a side oiler.
You can find these engines for well under 2k-3k for a core and they have no historical value. 427 top oilers are too few likely expensive to chance this on..
Better yet.. Go with a Genesis iron 427 repo.. I think those are in production now and would be better and cheaper in either case.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
