Old 05-11-2003, 09:45 PM
hcollado's Avatar
hcollado hcollado is offline
Cobra Make, Engine: Everett/Morrison- Boss 302 Stroked W/351W heads and a whole bunch of ponies
Thumbs up
Brent,
If you have a fax, I can fax them to you. The T fitting has to have a 1/2" NPT end in order to be able to screw into the valve.
By the way, I skipped the check valve. Instead I used a "Y" fitting on the return line from the oil cooler. Seems to work perfect. One of the tech guys at Canton recomended I stay away from a check valve that could fail and block all oil trying to get back to the engine.
Let me know
Hector
Hector Collado
Everyday is a Holiday ... every meal is a banquet.
