Old 05-12-2003, 10:08 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Default Banjo Bolt Seals
Hi Bob,
I'm getting slight brake fluid weepage around the banjo bolt connections to the front calipers. In your owners manual you mention that Earls makes some washers that might solve the problem. I assume you're referring to either Earl's Stat-O-Seals or their Dowty Seals. Which do you recommend and can you tell me whether I need the 3/8" ID or the 7/16" ID?
Chris
