Old 05-12-2003, 09:53 AM
Brent Mills's Avatar
Brent Mills Brent Mills is offline
Administrator
Wilf, I'll keep that in mind.
Roscoe, thanks for the link, which brings up another question....
Installing directly into the engines oil galleys
Some engine come with a predrilled inlet hole in the side of the block that will lead directly into an oil passage.
This can provide an effective way to plumb an Accusump directly into the block so that pressurized oil is discharged directly into the oil galleys.
Check with your mechanic or engine builder to see if your engine has this kind of provision.
Is this a possibility with a 427 s/o?
