For your intended use and RPM range, a hydraulic roller cam would be just the ticket. Not sure about Comp, but Crane makes hydraulic rollers for many older motors like FE's not originally equipped.
I used a CompCams retrofit hydraulic roller in a 351 Windsor and it is Awsome! This is a 224/224 duration, .533/.533 lift cam. It gets 16" vacuum at idle, pulls like a diesel from 1100 RPM up. Very streetable.
