Old 05-13-2003, 03:24 PM
M. Farcus M. Farcus is offline
At TWS, I typically see 155+ based on rpm and tire size (speedo isn't accurate) in ERA FIA car...I keep the front low as possible without screwing up roll center and have added a small aluminum air dam under the nose....helps some, but a 90" wheel base car will always be twitchy....using too stiff springs will add to the twitchy feeling.
MF
