Old 05-15-2003, 02:14 PM
a427sc a427sc is offline
Ant
I, too wanted to add stiffness to the central frame due the extreme stress I put into it. You are correct about possible flexing the windshield mounts the way I went, but I run a short "USRRC" type screen. If I had to run the full screen, it would be lexan filled, not glass. I question the torsional stability the central spine would give, with the small box section compared to the wider spacing down the outside. Plus, my way gave me some side protection that the tunnel doesn't. (Especially since I tend to "go agricultural" on a regular basis).
Don
