Old 05-20-2003, 12:55 AM
A Snake A Snake is offline
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
I think you'll find your cockpit dimensions are not the same as either of those cars. I'd suggest doing it on a "comfort for the driver" basis.
If you were using an OEM Motolita split ring 16" wheel and hub, with Volkswagen turn signal(which uses lever on the right side of column) the dimensions would then be of more benefit to you.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
