Thread: pull clutch
Old 05-22-2003, 09:33 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
All you need to do is go to one of the savages outside of town and ask for a bell housing and clutch fork from a late model Mustang or Capri (83-up). I know these all use the pull type clutch forks. Your engine has a boss on the drivers side for the clutch cable hardware. Probably for around $100 you should have everything you need.
However, going with the Toploader you need to be sure you are geared correctly for highway driving. What are the numbers on the aluminium tag on your transmission eg: "RUG AH" etc.?
This should be a good project for this weekend.
Clois
"Let's roll"
"Be part of Something Good
