I forgot to add the turkey pan the first time, so I added it to the list and brought this post up to the top again.
I'm rebuilding my early 64 427FE block for more compression ratio and horsepower since I've added a Weber induction system. Don't need these items. All are used but in excellent condition. Motor had only 20,000 miles. No problems of any kind.
Here’s what I have and my asking price. (or make offer):
390 crank (3U 3.784” stroke) $400
390 Heads (Ford cast iron – complete. Valve springs replaced Aug 2001. Not run much since) $800
Steel flywheel 184 teeth $150
Intake Manifold for single 4 barrel carb (believed to be Edelbrock Performer) $150
Melling
Oil Pump ME57HV with pickup for Cobra aluminum tee pan $50
Ford rods (C6AE-C 6.488” length) $400
Cam Techniques solid lifter cam (new in Aug 2001 : lift 0.561 at valve; duration of 232 deg at 0.050 lift; 108 deg intake C/L ) $150
TRW L2205 pistons $350
Holley 750 w/ Vacuum secondaries (3310) reworked by The Carburetor Shop’s Brad Urban for four corner idling, improved air channels and choke removal $200
Aluminum Turkey Pan $200
That’s the list. Please let me know if you are interested in any of these items. Thanks.
