Thread: EFI question
Old 05-24-2003, 01:19 PM
Robb Robb is offline
Send a message via AIM to Robb
Hum...
Read on one forum, the company that sells yearly online maintenance reports for your car (forget their name, though I had a subscription), that it may indeed be the wire in the mass air flow? sensor. Said that paper lint from cheap air filters gets on the wire, contaminating the grams per second count, which can cause similar problems.
Going to investigate further, re-connect a code scanner, change the o2 sensors (they need it anyway), and I'll get back with you all about the results.
-Robb
