I was also going to add that it sounds like you didn't have enough time in it when you went down to 10 degrees...if it's backfiring out the carb, then I'd say you need to go the other way.
![Smilie](images/smilies/smile.gif)
You were probably on the right track when you had 20 degrees initial in it. Without a dyno, it's hard to tell...
