Old 05-27-2003, 01:00 PM
petek's Avatar
petek petek is offline
Cobra Make, Engine: CRL, 351W, Tremec TKO
Thanks Hawk.
In answer to your questions:
0... far enough so the tilt lever clears the dash. (Not much of an
answer, I know).
1... there should be some rubber "C" shapped thingies (technical term). Use an in-line filler.
2... I mounted mine on the passenger's side right next to the fuel tank on a bracket I made.
3... any thick battery cable will work. Just make sure you get cable ends that you can pass a bolt through.
Pete K.
Who is John Galt?
