Originally posted by Double Venom
Tony Branden has them. We just ordered a set for "Jenny's FIA car! Problem is, they only fit the OEM skinny plug wires!
DV.. It IS cookie time!
I bought these from Branda as well, and I had the MSG 9.5 mm wires! No problem though. These looms are soft plastic, so I just put an appropriate sized drill bit in my drill press and carefully "hogged" out the openings so they will accomodate larger ignition wires. Put the loom on a block of wood to make the drilling easier and more accurate. It's a PITA, but if you go slow, no one will know you did it and they work beautifully.
