Old 05-28-2003, 10:58 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Also have Ididit tilt steel column. Paint it rattle can wrinkle black and it will match the steering wheel Lecarra mount. Use CR upper column mount under dash. Use 2" muffler clamp at column firewall exit to eliminate any column movement whatsoever.
Ground battery directly to the starter. Then from the starter to the frame. The frame should be a secondary ground. All grounds should be wired primarily to a central (non-frame) wired ground return to the battery ground (similar to household wiring) for a fiberglass car with the frame being only a redundant ground.
