Originally posted by Ikestaa
What all did you change?
Lots of small stuff to get closer to the original:
1. Front anti-sway bar moved under the floor.
2. Optional integral seats instead of the separate buckets.
3. Pedal assembly hung from the top - easily adjustable from the driver's seat.
4. Floor has integrated transverse flutes.
5. Cooling tube bump in the front is rounded on top.
6. Wider tunnel for larger MK2 cooling tubes.
7. Larger access to fuel cell access plate.
8. Room for larger fuel tanks.
9. Provision for mounting battery on rear subframe.
10. Lots of internal chassis mods for easier assembly.
11. New flutes on the rocker tops
12. Wiring harness changes (already implemented) with a new firewall module prewired.
I think that covers it.
