If I understand correctly...
It seems that you have a bad rear engine bearing and/or seal. It's a common problem on most motors. If it's bearings, that indicates wear inside. If it's just a tired or incorrectly installed seal, it's just a hassle of dropping the tranny and replacing it. A good shop manual can describe how to test for bearing slop (wear) while you have it apart...
If your seals are actually dry, then it has to be a cracked block ? Is there any plug/repair in there that could be loose?
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
