Spoony, If you plan on racing the car you have some considerations. Otherwise, you have all you will ever need on the street. You can break the tires loose at most any time in the first 3 gears. Your exhaust sound is better than most cars on the street. Plus, it is driveable. I have a SPF with this engine.
Oil and water temps are fine. This engine will probably live a little longer than the stroker.
We always want more, but why, if you can't use it.
Lynn
