Old 05-30-2003, 09:28 PM
petek's Avatar
petek petek is offline
Cobra Make, Engine: CRL, 351W, Tremec TKO
Ernie,
Worked fine on my Cobra's pipes before I had them ceramic coated, works fine after I had 'em ceramic coated (O2 sensor located right at the point the four tubes collect together).
If you are using two sensors, how to you connect them together to feed the ECU? (Or does your ECU expect to have to sensors?)
Pete K.
Who is John Galt?
