I am referring to the linkage.. the Demon carbs do not work with a standard Ford / Holley linkage assembly.. I'm wondering what you found that will work.
I take it from the reply you haven't gotten to that point yet. it isn't a big deal to fab a linkage but the way the way the demons are shaped precludes going under the float bowl with a standard sized crossover rod.. using a smaller rod is problematic given it will flex. It would be possible to grind enough clearance into the intake and use a modified bracket.. I just couldn't do it to an original manifold.
Good luck. let us know what you come up with.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
