Old 05-31-2003, 07:59 PM
Bubb Rubb Bubb Rubb is offline
Originally posted by SCOBRAC
What was the compression readings you got before you tore it down? It isn't rocket science but you can correlate the pressure with the C/R
To some extent, yes, but in other ways you can't correlate it at all. Short cam duration will cause cranking cylinder pressure to go up. Long duration will cause cranking cylinder pressure to be way down. That's why a high compression engine with a big cam might produce less CRANKING (key word) compression than a low CR engine with a short cam.
You are best off measuring everything and doing the math.
