I have a Mcleod and I am very happy with it. It was easy to install, no adjustment needed, and easy to bleed. You give them your mesurements and they build it and ship it in a couple of days. I was told not to let it sit for long periods of time without being used so even in the dead of winter I go out in the garage and pump the pedal 4-5 times every couple of weeks. As far as the leaking in a couple of years, I have not had it that long but I will tell you that when you recieve it from Mcleod it comes with a complete set of extra 0-rings. ( tells you something)
I have a 3/4" Wilwood master cylinder and it works fine.
Cost of the bearing is about 350.00 if memory serves me.
I would use hard line from the cylinder to the hook-up lines for the bearing, braided lines swell and make the clutch act funny.
Good luck.
