Hold on a minute...
I converted my system to a McLeod unit last fall and would do the same again in a heartbeat. Precise measurements are needed to protect yourself from "over-extending" the piston but once done it is so nice NOT dealing with a mechanical linkage. Another benefit - at least with the McLeod is is is self adjusting for the life of the clutch providing you originally measured correctly. It is expensive but then again what isn't with an FE. Best of luck!
Cracker
