Old 06-02-2003, 12:57 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Put 4 jack stands under your car with the front higher than the back. Put your jack with a block of wood under the rear or your engine oil pan. Remove your bolts for your motor mounts (the long horizontal ones). The engin should tip backwards enough so you can get your bell housing out. Or you could just pull the body off
I am helping a friend with his tonight and I will tell you tomorrow how it goes. If push comes to shove we do have a cherry picker to lift the front of the engine. He just dropped a new rebuild in his Cobra this weekend and put his clutch in backwards. He tells me it makes a lot of noise when he pushed in the clutch.
I will not make any comments given the problems I have had lately. Things just happen sometimes...
Good Luck!
Clois
"Let's roll"
"Be part of Something Good
