Old 06-04-2003, 04:55 AM
Janus Janus is offline
Cobra Make, Engine: KCC Venom, 390FE Edelbrock RPM Package
Thanks for the feedback!
Should I decide to go with the external arrangement, what would one need to get and modify?
Does one need to change the fulcrum point for the clutch fork? I am using a SCJ bellhousing and fork with a 3/4" adapter spacer.
Does the fork need some shortening, mods? The piece of spring steel, riveted to the fork, has the end piece missing. Can you get these separate? A new fork a better alternative? Who sells them?
You'll need to fabricate some bracket to accommodate the external cylinder. Anything special here?
What cylinder combinations work well? Any suggestions?
