Old 06-04-2003, 08:30 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I put together external slave setups using a factory stock fork and TO bearing, a 6" long piece of 2" 90 degree steel channel to make a bracket (cut drilled and ground in various ways), and then looked through the catalog to find a slave cyl that was the rght length and bore diameter, I think it was a ford probe slave? Getting the ball stud adjusted just right is critical so you don't waste slave travel. Or you can just buy a kit from one of the suppliers.
