Old 06-04-2003, 12:24 PM
jayhawk261 jayhawk261 is offline
You need to buy a couple of breathers. One will be a standard breather and the other will be for a PCV valve. The hose you see going from a breather to the carb base plate is the from the PCV valve. There does need to be an outlet for built up crankcase pressure. I've even seen some breathers blown out of their holes.
