Old 06-04-2003, 04:17 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
If "Loud" can't be defined, and quantified it can't be enforced. It's the cop's "Opinion" against yours, abd even representing yourself pro se', you could beat it. Excessive noise has to be first measurable. 95db at 50 feet for instance. The measuring instruments must be calibrated and certified, and the cop must provide documentation azs to his/her training received to use the instrument. The conditions under which the measurements are taken must be described in the statute, or procedure. Uphill, downhill, highway cruise, 35mph, idling? Now, a defective, or malfunctioning exhaust could be a trial issue. If your car has a recent State inspection, or you go and get another one demonstrating no defect, or malfuinction in the exhaust system, The judge will ask you if you have had your muffler repaired. You must state, and document, that your muffler was not defective on the date the violation was written, and therefore no repairs were required. You're "Not Guilty".
