Thread: Vibration
Old 06-05-2003, 09:08 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
If it is your engine or clutch, than vehicle speed is irrelevant, it will do it with the car sitting still if you bring up the RPM's. I bet the tires/wheels. If you can swap tires and wheels with a buddy, that is the best way to check. I have had this problem on customer's cars before, the tire shop says the tires are balanced perfectly, but swap them out for a different set and the problem follows the wheels/tires, not the car.
