Old 06-07-2003, 07:43 PM
Ikestaa Ikestaa is offline
Okay, we got the leak fixed and the entire brake system bled. Problem is, the pedlle is still soft. It will go all the way to the floor. There is no air coming out of any of the calipers, or out of the master. Any suggestions on what to do?
Also, I tried running a wire straight from the MSD to the tach and still nothing. It just sits at 2100. Is there some sort of test I can do for both the gauge and the MSD? Can I use a multimeter to read voltage or current coming out of the box, and can I induce some kind of current across the tach to see if it functions?
2500 Pounds of steel, rubber, and fire. AAAHHHH!
