Old 06-09-2003, 05:09 AM
dmfconsult dmfconsult is offline
Default High Pressure Oil Pump??
I've decided to change my old banged up oil pan ( 302 double hump). The new pan came with a pick-up which I will install and since I do not have a history of the engine (mid to upper 1980's with a cam, upgraded valve springs, 650 holley etc.), I think I will replace the oil pump and shaft while I have the pan off.
The Question;
Would I be better off for any reason to install a high pressure oil pump? A high volume oil pump? Or a manufacturer spec. oil pump?
