Old 06-09-2003, 07:23 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Cobra, I use the Napa mount # 602-1639. They are rubber mounts which will work just fine in the car. I don't know of a poly mount. Leave the frame mounts loose until you have everything lined up. You may also have to leave the motor mounts loose. I wouldn't recommend solid mounts. You will feel all the engine vibration.
Don
