Old 06-09-2003, 12:16 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Ike,
I had a similar problem with my SW tach. ERA replaced it and the new one works fine. The tach output signal at the MSD box is a square wave. The multimeter you use should be a "true RMS" type. If you use a "cheapy" meter it probably won't be a true RMS type and it will give you erroneous readings.
Chris
