Old 06-10-2003, 05:02 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Go with Mr. Fixit's advice. Use ARP studs on your Windsor 2 bolt. There is a set of Milodon center 3 caps that could be used, but not sure it would be worth it. Spend the money on the crank, rods, and pistons.
Same with advice on females. The mousy ones are always the hottest between the sheets, and easiest to live with.
