Old 06-13-2003, 07:03 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Originally posted by CJ428CJ
using a long duration cam will allow higher compression ratios (the valves are open longer which prevents the cylinder pressure from getting as high as it would in a short duration cam). .
Chris [/b]
This is not true.... my cam has .667 lift, 261@50 and 291 total and has 285 lbs cranking pressure....lobe seperation and overlap all play a part of cranking pressure
Jack
XSSIVE .....
