Old 06-13-2003, 10:05 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Thanks Don. I can do what you suggest but that's just cutting and pasting. Since it's a table, the column alignment gets goofed up. I was trying to imbed the image within the message as either a pdf or tif file. Kind of like what some people do when they put photos within their post. Until someone can tell me what I did wrong, here's the data in its raw unformatted form:
# Mfg Part No. Type HP @RPM Torq @RPM Lift(Int/Ex) Dur Dur@.05 Sep.
1 Isky 351271 Hyd 443 5000 511 3000 .542/.542 280/280 232/232 108
2 Comp 33-519-3 Hyd 446 6500 420 4500 .580/.580 306/306
3 Comp 33-241-3 Hyd 448 6000 436 4500 .580/.580 305/305
4 Crower 16241 Hyd 451 5500 509 3500 .538/.552 280/286 222/228 112
5 Crane 344561 Hyd 453 5500 470 4000 .572/.572 236/236 108
6 Edel 7106 Hyd 453 5500 470 4000 .572/.572 296/296 236/236 108
7 Crower 16255 Hyd 456 6000 500 3000 .549/.550 280/288 224/232 108
8 Crane 343801 Hyd 457 5500 500 4000 .537/.537 288/288 226/226 112
9 Isky 351281 Hyd 458 5500 493 4000 .565/.565 232/232 108
10 Comp 33-240-3 Hyd 460 6000 482 4500 .560/.560 292/300 111
11 Comp 33-310-4 Hyd 462 5500 507 3500 .550/.550 276/284 110
12 Comp 33-230-4 Hyd 465 6000 502 3500 .530/.530 280/280 110
13 Comp 33-316-4 Hyd 465 6000 459 4500 .590/.590 296/305 110
14 Comp 33-317-4 Hyd 467 6000 476 4000 .560/.590 292/296 110
15 Lunati 00054 Hyd 468 5500 490 4500 .554/.554 292/292 230/230 109
16 Comp 33-314-4 Hyd 469 5500 501 4000 .560/.560 280/288 110
17 Comp 33-315-4 Hyd 471 5500 491 4500 .570/.560 286/292 110
18 Crane 344621 Hyd 475 6000 461 5000 .554/.563 296/300 234/238 112
19 Lunati 30507 Hyd 475 5500 485 4000 .563/.600 280/290 230/240 108
20 Crane 343801 Hyd 477 5500 499 4500 .548/.580 278/290 222/234 114
21 Comp 33-312-4 Hyd 483 6000 481 4500 .570/.560 286/292 108
22 Crower 16462 Sol-Rol 502 5500 573 3000 .580/.582 280/288 234/244
23 Crane 349541 Hyd-Rol 510 6000 471 4500 .632/.655 300/308 238/246 112
24 Crane 349521 Hyd-Rol 526 6000 534 4500 .584/.607 284/290 222/228 110
