06-15-2003, 02:48 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thanks Pete......Glad to hear I'm not the only one with the same problem. The pedals can be cut and rewelded as far as 4 or 5 inches to the right with no problem. I thought of just cutting the tunnel and reglassing a new section into it, but it's not a simple cut and the effect on the firewall would be dramatic...requiring not only new paint, but almost surely the removal of engine and tranny. I wasn't looking forward to that if I could get away without doing it. I don't know what the double wall thickness is to the left of the clutch.....perhaps that could be massaged a little, but I'd rather hear from someone who has already addresssed this issue and has a solid solution.
Bill
