Old 06-16-2003, 12:45 PM
mikey mikey is offline
Default Starter motor heat soak
Hi guys.
After fitting Tremec with new starter I am now experiencing the problem of heat Soak. When hot, starter motor will not even actuate until it cools down. I fitted themal shielding directly around the motors body, but I think this may have made it worse as on a long run, it is probably keeping the heat in, or thats my guess.
There is not enough room between the headers and the starter to get a heat shield with an air gap so I am thinking do I need a mini high torque starter.
Do they work, anybody got any experience that has had this problem. Also is it possible to change the orientation of the solenoid.
Any help would be very welcome.
Thanks.
Mike.
Mikey B
