Robb,
Most likely the TPS sensor, on the throttle body, 1" oval held on with 2 screws, should only be $30 at Napa. Just plugs into a factory conector. The carbon in the variable resistor breaks down and doesn't give the proper voltage[ 0.8 to 5 volts ] to the computer.
Good Luck,
Perry.
