Excaliber never had a small block frame. They used the same frame as CR which would accept big or small blocks. The small block frame with the larger footwell started around 1999. The only modification you could get before that was a modified firewall which very few were done, and were done by me. CR still has both frames available. DV said he has installed a big block in the small block frame without any problem which would be great because of the added footroom. Maybe DV can tell us which engine he installed.
Don
