Thread: cheap power
Old 06-23-2003, 09:07 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You will spend most of your money on maching the block, buying new pistons, rings, gaskets, cam lifters, timing chain, oil pump, valve job, etc. Just rebuild it, put a small duration cam in it, dual plane intake and a vac secondary carb. Don't bother porting the heads, buy headers instead.
