Welllllll.....now you've got a lot of choices to make.....I've used 15 and 16 and 17 inch rims. 3 1/2" is about all the front spacing you can handle. I think my 17 were 9.5x17 with 6.5 back spacing, also believe my 15's are about the same. The 17's were 9.5 all the way around and the 15's and 16's were 8.5 fronts and 9.5 rears. You can probably get 11's on the rear, with a little more front spacing...the one set of 11's I tried had a little to much back spacing and rubbed....bolt pattern is 5 x 4.75
Jack
XSSIVE .....
